ONEX #54 Web Site
Date:  2-26-2014
Number of Hours:  0.00
Manual Reference:  B06-02
Brief Description:  Optional wing locks
Cut 2x2x3/16 raw material for the optional wing locks.
Fabricated one set of the Main Wing Lock Attach Brackers, B06-02.
I had difficulty getting the main spar pin in place. I had to file the root of the angle by the 3/8" lock pin hole to almost a square angle to get the parts to fit. The radius of the extrusion at the root causes interference with the wing slot. On the next set I'll move the 1-3/8" hole dimension out about 1/16" to move the root radius farther away from the wing slot.
Added my weight and balance information to the Garmin AV8OR GPS unit. The unit has a convenient WB calculator built in.
B06-02 with squared root on the right
B06-02 located in main spar lock pin
WB graph on Garmin AV8OR
